Intel 350-T4 Network card driver help
OzDeaDMeaT
Hi everyone,
First time poster. I have a small problem with a Intel I350-T4 4 port gig NIC I purchased for work a couple of weeks ago. I can't seem to get it working in our older servers (HP DL385g2's) that I am looking at turning into an iSCSI target. Looking at the dmesg it says it can't find drivers for this hardware. The strange thing is I am using the exact same freenas installer cd (8.0.4 x64) at home on my HP Microserver and it has detected the I350-t4 cards 4 nic's happily. As I am a relative noob when it comes to Linux could someone help me get this resolved?
I am sure its something simple, I just need some guidance on what to do next.
Cheers,
OzDM
[edit] The servers firmware is up to date [/edit]
louisk
Sounds like an issue with the HP DL385g2. Have you tried any other OS, or talking to the vendor to confirm compatibility?
OzDeaDMeaT
RedHat 6, Windows 2008r2 and VMware 5 are all picking up the nic's. Seems to be only related to Freenas. Is there a way to force the driver to load towards a particular piece of hardware?
OzDeaDMeaT
Info from box
Cant write the info into the thread so I had to attach the files instead.
  • pciconf -l -v.txt
  • dmesg.txt
louisk
Which driver is it using on the micro server? You might try adding a loader.conf variable to force the driver to load.
