Hi, I´m quite new on VPNs and advanced networking. When I had freenas 11.1 I had zerotier as VPN because setting up an openVPN was very difficult for me. After upgrading to Truenas 12 Stable Zerotier is not longer suported and decided to try a VPN, and read about Wireguard so I spent these weeks learning and tring how to do it.
My system now has an ip 192.168.0.10 (for the system with the WebUI) and two jails, one for PlexMediaServer and another one to access my data, downloads, and whatever I need.
I followed this tutorial to create a Wireguard Server on a Jail
www.truenas.com
It creates a jail with IP 172.16.0.2/30 and 10.0.01 in the Wireguard subnet as the wireguard server
Then I installed Wireguard in my allpurpose Jail following this tutorial:
www.cyberciti.biz
That jail is 192.168.0.3/24 and 10.0.0.3/32 in the Wireguard network and is reachable from outside from 10.0.0.2 my android phone client for example.
(sometimes is not reachable I don´t know why, and have to restart the Jail, but that´s not the point of this thread)
And I want to access the WebUI of my freenas System from outside for example If I have problems accessing the jail and I want to restart that jail.
My main ip where the Truenas system is is: 192.168.0.10
I try to install a wireguard client there with this steps:
adding two tunables in the webui-system-tunables: “wireguard_enable” -> “YES” in rc.conf and “wireguard_interfaces” -> “wg0” in rc.conf
and a postinit scrip to put the wg0.conf file in the correct place after a reboot: “cp /root/wg0.conf /usr/local/etc/wireguard/wg0.conf && /usr/local/etc/rc.d/wireguard start”
my wg0.cong file in the Truenas System client is:
and when I reboot I the truenas system ip is not reachable, and the whole Wireguard VPN doesn´t work.
I don´t know what to do, and searcherd a los in the forums and goolgle.Any light woulf be much apreciated. I know it´s difficult to know what happens with my english and this poor data. ask me if you need more info.
in the truenas shell it shows not receiving data:
Thak you very much for the help. I don´t know where to continue...
petoniano
How-To: Setup a Wireguard VPN Server in a Jail
This resource was originally created by user: FreeVel on the TrueNAS Community Forums Archive. Please DM this account or comment in this thread to claim it. Goal To setup a VPN server based on the Wireguard technology and running from within a Jail. The VPN server would allow remote devices...
root@WGServerJail:~ # ifconfig lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> pflog0: flags=0<> metric 0 mtu 33160 groups: pflog epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether d2:50:99:71:13:2a hwaddr 02:06:39:e2:c7:0b inet 172.16.0.2 netmask 0xfffffffc broadcast 172.16.0.3 groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERF
How to install a Wireguard VPN client in a FreeBSD jail - nixCraft
Explains how to install and set up WireGuard VPN client for FreeBSD jail running either on FreeNAS or FreeBSD host.
root@freenas:~ # ifconfig igb0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=e527bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6> ether d0:50:99:c2:a0:87 media: Ethernet autoselect status: no carrier nd6 options=1<PERFORMNUD> em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: freenas_ui options=812099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER> ether d0:50:99:c2:a0:88 inet 192.168.0.10 netmask 0xffffff00 broadcast 192.168.0.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active nd6 options=9<PERFORMNUD,IFDISABLED> lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6> inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3 inet 127.0.0.1 netmask 0xff000000 groups: lo nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL> pflog0: flags=0<> metric 0 mtu 33160 groups: pflog wg0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> metric 0 mtu 1420 options=80000<LINKSTATE> inet 10.0.0.10 --> 10.0.0.10 netmask 0xffffffff groups: tun nd6 options=101<PERFORMNUD,NO_DAD> Opened by PID 1810 bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:f9:ca:ee:fe:00 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: vnet0.5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 11 priority 128 path cost 2000 member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 10 priority 128 path cost 2000 member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 9 priority 128 path cost 2000 member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 7 priority 128 path cost 2000 member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 2 priority 128 path cost 20000 groups: bridge nd6 options=1<PERFORMNUD> vnet0.1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: WGJ2 as nic: epair0b options=8<VLAN_MTU> ether d2:50:99:1f:f8:25 hwaddr 02:06:39:e2:c7:0a groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERFORMNUD> vnet0.2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: WGServerJail as nic: epair0b options=8<VLAN_MTU> ether d2:50:99:71:13:29 hwaddr 02:30:17:69:45:0a inet 172.16.0.1 netmask 0xfffffffc broadcast 172.16.0.3 groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERFORMNUD> vnet0.3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: freebsd_pkg as nic: epair0b options=8<VLAN_MTU> ether d2:50:99:ef:26:f8 hwaddr 02:b7:e9:66:b8:0a groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERFORMNUD> vnet0.4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 description: associated with jail: openspeedtest as nic: epair0b options=8<VLAN_MTU> ether d2:50:99:62:52:c3 hwaddr 02:ea:f8:ce:3e:0a groups: epair media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active nd6 options=1<PERFORMNUD> vnet0.5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
root@freenas:~ # cat wg0.conf
[Interface]
Address = 10.0.0.10/32
PrivateKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=
DNS = 8.8.8.8
[Peer]
PublicKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX=
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = my_public_IP_from_ouside:51820
root@freenas:~ # wg show interface: wg0 public key: XXXXXXXXXXXXXXXXXXXXXXXXXX= private key: (hidden) listening port: 40847 peer: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx= endpoint: 188.XXX.XXX.XXX:51820 allowed ips: 0.0.0.0/0, ::/0 transfer: 0 B received, 24.43 KiB sent root@freenas:~ #
petoniano
