SOLVED Installation using Wizard failed on LDAP/AD/NIS step
isagarran
Configuration :
  • MotherBoard socket 1155 MSI H67MA-E35 (Revision B3).
  • FreeNAS FreeNAS-11.0-U3 (c5dcf4416)
  • 6 disks Seagate Barracuda 2Tb
  • Memory 8Gb
  • OCZ PSU ZS550W-EU - ZS Series, 550W 80Plus Bronze
  • Processor Intel® Celeron® Processor G530 (2M Cache, 2.40 GHz)
  • I intent to configure RAIDZ2 as advised by senior FreeNAS
  • CD/DVD device for installation
  • SSD SATA device connected as USB device
Finally I finished Freenas installation and I tried to configure Freenas using wizard but I got an issue and perhaps I'm wrong somewhere. Could you help me ?
  1. I clicked on Wizard,then
  2. I clicked next on Keyboad configuration. I don't modify something ( I did previously and I changed my Keyboard as a French keyboard)
  3. I specify the Volume name ISAGARRAN_VOL and RAID Z2 option. It shows me "Estimated size 7,3TB - Disks to be formatted: ada0, ada1, ada2, ada3, ada4, ada5" then next
  4. I got the Active directory/ldap/nis fields. I don't have them, I expect to pursue clicking on Next and the wizard shows DNS field required.
the only option is to exit from the wizard. My volume is not automatically configured.
Do you have any idea ?
Isagarran
isagarran
Pb is solved. I blanked userid/password that were automatically filled with my root/password
regards.
Isagarran
