installation freenas
carber20
hello
I want to install on my freenas clée usb error
D
dlavigne
Guest
Which version of FreeNAS? Size of USB stick? How did you perform the install?
carber20
freenas download latest version of their site
clée size usb 1GB
installation from the CD
enemy85
You need at least a 4gb usb stick. Better a 8gb one! Read the manual.
carber20
I tested with USB 8GB clee well as an external disk 1 to I still have the same problem
enemy85
give more details...hardware specs?
carber20
Pc hp 7100 avec deux disque dur installer en sata de 80 go chacun
Voilà picture error
enemy85
The problem is your hw. I'm sorry to say that but freenas won't never run on that pc. Please reade the hw requirements of freenas and you will see your hw is far far away from what are the MINIMUM requirements
