Freesnofla
- Oct 27, 2013
Hi all,
I was a former user of a Synology Diskstation but find out later on that there are other possibilities, and I started to build my own NAS. The below list shows the items i used for the NAS. I guess that one is fine and powerful enough.
As I learned that the operation system needs a own drive I invested in a Samsung 840 Series Basic SSD with 120 GB.
SilverStone Lascala LC13-E silber
Arctic Cooling Alpine 64 Pro 92mm 500-2000rpm
Gigabyte GA-870A-UD3 870 Sockel AM3 ATX DDR3
AMD Athlon II X2 240e 2x 2.80GHz AM3 Box 45W HDGM
Kingston 8GB KIT PC3-8500U DDR3-1066 CL7 Value
2 x Samsung EcoGreen F4 2000GB SATA II 32MB 5400rpm
That's actually my Hardware for the NAS.
I was then starting with OMV and got it fixed after a while, so the system was running but not that stable. That's why I was searching for a alternative and found by the way FreeNas where I already viewed a lot of the Video tutorials. The system sounds interesting to me, and I like to go for it.
What is causing me a bit headache, how I can re-install that system from OMV to FreeNas. What kind of work have I to do so I get a clean system setup?
I will of course do a backup of the files I have on the NAS right now, then I would create a USB drive from where I will install the FreeNas system into the SSD. Is it able to use Unetbootin for that purpose or are there any other easier ways?
What about the existing installation OMV how do I delete that one, or will that one get deleted when I do the FreeNas installation?
Hope you would give me some hints.
best regards
freesnofla
best regards
freesnofla
