Greetings! My next question...
I am working on replicating some data (About 5 TB) from FreeNAS server A to FreeNAS server B as an interim to reclaim some disks that I will be using in FreeNAS server C. I am having challenges in getting reasonable throughput between the systems. The systems are directly fibered to eachother on 10Gbps NICs. Iperf comes back with 9.38 Gbps. I have tried RSYNC with about 150 Mbps throughput, and I have tried replication with about 500 Mbps throughput. I know the disks and controllers are likely to bottleneck before the NICs but I feel like I should be able to get much closer to the controller speed of 6 Gbps. When mounting ISCSI shares from the pools I see read and writes in the 3+ Gbps range (450 MBps in crystal disk). Anything stand out that I am missing? I have a few other options that will work but are slower and I wanted to leverage the 10Gbps NICs for the initial replication.
Server A:
Build: FreeNAS-9.10.2-U4 (27ae72978)
Platform: Intel(R) Xeon(R) CPU L5630 @ 2.13GHz x 2
Memory: 16345MB
Disk: 12 x 1TB in Raid-Z3
Controller: 8 disks on LSI 2008-IT 4 disks on onboard SATA
Server B:
Build FreeNAS-9.10.2-U3 (e1497f269)
Platform Intel(R) Xeon(R) CPU E5-2450L 0 @ 1.80GHz
Memory 49088MB
Disk: 14 x 1TB in Raid-10
Controller: 14 disks on LSI 2008-IT
Server A:
Memory: 16345MB
Server B:
Memory 49088MB
