INIT/SHUTDOWN ON SCHEDULE
xames
I need to shutdown freenas that only active during replication, and start 30 minuts before replication, how i can do that?
Thanks.
Fredda
Init: Can't be managed by FreeNAS. Some BIOS support to turn on a computer at a certain time. Or you could try it with Wake on Lan.
Shutdown: Tasks --> Cron Jobs
norbert.hanke
I do it with wake-on-lan from a cronjob: wake <backup:server:mac:address:here>
15 Minutes later after discs have warmed up I run the replication, followed by
ssh -i <privatekey> <backupserver> shutdown -p now
You need to register the public key with the root account on the backup server first.
xames
Can you write and example command please, i don't understand.
norbert.hanke
To wake up the other system: wake 51:e4:47:40:16:60
where that parameter is the macaddress of the system.
To find out the macaddress: in a command shell, ping the system and then execute arp -a and look for it.
To shut down the system: ssh -i ~/.ssh/id_rsa <servername> shutdown -p now
You can google for a decent guide on how to create that id_rsa file using ssh-keygen and how to register the public key in ~/.ssh/authorized_keys on the server side.
das1996
The shutdown works well but how does one test if a replication process has completed?
