Incorrect reporting of Critical Error
Shane Bolton
I just got this email:
The volume vol01 (ZFS) state is DEGRADED: One or more devices has been removed by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state.
I checked the volume in about 1 minute from receiving the email. Nothing wrong. Everything was OK.
Bidule0hm
Server Electronics Sorcerer
Please post the output of zpool status -v between code tags.
Shane Bolton
zpool status -v is below:
pool: vol01
state: ONLINE
  scan: resilvered 44K in 0h0m with 0 errors on Sun Feb 14 21:15:49 2016
        NAME                                            STATE     READ WRITE CKS
UM
        vol01                                           ONLINE       0     0
0
          raidz1-0                                      ONLINE       0     0
0
            gptid/ce2dad98-d2b4-11e5-8520-001fd0831e05  ONLINE       0     0
0
            gptid/cf5a43f1-d2b4-11e5-8520-001fd0831e05  ONLINE       0     0
0
            gptid/d079415f-d2b4-11e5-8520-001fd0831e05  ONLINE       0     0
0
errors: No known data errors
Bidule0hm
It has resilvered 44 kB with success so that's why the pool is now healthy again.
Now the question is why it had 44 kB corrupted. Can you post the full list of your hardware and the output of smartctl -a /dev/adaX for each drive, between code tags (4th button from the end in the editor, 3rd item in the list), please.
Shane Bolton
Config:
Intel Core 2 Duo.
8GB RAM
ada0, ada2, ada3 = 2TB Seagate = ZFS1 Volume
ada1 = 160GB (not used or configured.)
[root@nas02] ~# smartctl -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family:     Seagate Barracuda Green (AF)
Device Model:     ST2000DL003-9VT166
Serial Number:    5YD1CYB4
LU WWN Device Id: 5 000c50 02f3ff133
Firmware Version: CC32
User Capacity:    2,000,397,852,160 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5900 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Feb 14 23:20:33 2016 AEDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         (  623) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 344) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x30b7)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   105   099   006    Pre-fail  Always       -       1234336
  3 Spin_Up_Time            0x0003   093   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   092   092   020    Old_age   Always       -       9058
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       724855745
  9 Power_On_Hours          0x0032   035   035   000    Old_age   Always       -       57298
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       173
183 Runtime_Bad_Block       0x0032   090   090   000    Old_age   Always       -       10
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   099   099   000    Old_age   Always       -       1
188 Command_Timeout         0x0032   100   097   000    Old_age   Always       -       8590065720
189 High_Fly_Writes         0x003a   070   070   000    Old_age   Always       -       30
190 Airflow_Temperature_Cel 0x0022   064   046   045    Old_age   Always       -       36 (Min/Max 24/39)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       123
193 Load_Cycle_Count        0x0032   096   096   000    Old_age   Always       -       9059
194 Temperature_Celsius     0x0022   036   054   000    Old_age   Always       -       36 (0 12 0 0 0)
195 Hardware_ECC_Recovered  0x001a   009   003   000    Old_age   Always       -       1234336
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       38875 (253 34 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1584165110
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1239827477
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     52987         -
# 2  Short offline       Completed without error       00%     52925         -
# 3  Short offline       Completed without error       00%     52873         -
# 4  Short offline       Completed without error       00%     52811         -
# 5  Short offline       Completed without error       00%     52755         -
# 6  Short offline       Completed without error       00%     52704         -
# 7  Short offline       Completed without error       00%     52648         -
# 8  Short offline       Completed without error       00%     52596         -
# 9  Short offline       Completed without error       00%     52531         -
#10  Short offline       Completed without error       00%     52473         -
#11  Short offline       Completed without error       00%     52406         -
#12  Short offline       Completed without error       00%     52362         -
#13  Short offline       Completed without error       00%     52303         -
#14  Short offline       Completed without error       00%     52270         -
#15  Short offline       Completed without error       00%     52233         -
#16  Short offline       Completed without error       00%     52193         -
#17  Short offline       Completed without error       00%     52139         -
#18  Short offline       Completed without error       00%     52087         -
#19  Short offline       Completed without error       00%     52063         -
#20  Short offline       Completed without error       00%     52039         -
#21  Short offline       Completed without error       00%     52015         -
[root@nas02] ~# smartctl -a /dev/ada2
Serial Number:    5YD1DQLA
LU WWN Device Id: 5 000c50 02f46937f
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Local Time is:    Sun Feb 14 23:23:55 2016 AEDT
See vendor-specific Attribute list for marginal Attributes.
                    been run.
data collection:         (  612) seconds.
                    command.
                    power-saving mode.
recommended polling time:      ( 331) minutes.
  1 Raw_Read_Error_Rate     0x000f   102   099   006    Pre-fail  Always       -       1132256
  4 Start_Stop_Count        0x0032   092   092   020    Old_age   Always       -       9047
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       732004161
  9 Power_On_Hours          0x0032   035   035   000    Old_age   Always       -       57454
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       202
183 Runtime_Bad_Block       0x0032   094   094   000    Old_age   Always       -       6
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   096   000    Old_age   Always       -       4295032884
189 High_Fly_Writes         0x003a   001   001   000    Old_age   Always       -       135
190 Airflow_Temperature_Cel 0x0022   063   045   045    Old_age   Always   In_the_past 37 (Min/Max 25/40)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       148
193 Load_Cycle_Count        0x0032   096   096   000    Old_age   Always       -       9048
194 Temperature_Celsius     0x0022   037   055   000    Old_age   Always       -       37 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   030   003   000    Old_age   Always       -       1132256
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       38996 (92 68 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2280846010
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       3234290346
No Errors Logged
# 1  Short offline       Completed without error       00%     53048         -
# 2  Short offline       Completed without error       00%     52984         -
# 3  Short offline       Completed without error       00%     52934         -
# 4  Short offline       Completed without error       00%     52873         -
# 5  Short offline       Completed without error       00%     52814         -
# 6  Short offline       Completed without error       00%     52764         -
# 7  Short offline       Completed without error       00%     52710         -
# 8  Short offline       Completed without error       00%     52654         -
# 9  Short offline       Completed without error       00%     52589         -
#10  Short offline       Completed without error       00%     52534         -
#11  Short offline       Completed without error       00%     52470         -
#12  Short offline       Completed without error       00%     52428         -
#13  Short offline       Completed without error       00%     52370         -
#14  Short offline       Completed without error       00%     52337         -
#15  Short offline       Completed without error       00%     52300         -
#16  Short offline       Completed without error       00%     52258         -
#17  Short offline       Completed without error       00%     52205         -
#18  Short offline       Completed without error       00%     52152         -
#19  Short offline       Completed without error       00%     52128         -
#20  Short offline       Completed without error       00%     52104         -
#21  Short offline       Completed without error       00%     52080         -
[root@nas02] ~# smartctl -a /dev/ada3
Serial Number:    5YD16KY3
LU WWN Device Id: 5 000c50 02f24f2af
Local Time is:    Sun Feb 14 23:26:52 2016 AEDT
                    been run.
                    command.
                    power-saving mode.
recommended polling time:      ( 345) minutes.
  1 Raw_Read_Error_Rate     0x000f   105   099   006    Pre-fail  Always       -       1039168
  3 Spin_Up_Time            0x0003   093   089   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   092   092   020    Old_age   Always       -       8414
  7 Seek_Error_Rate         0x000f   088   060   030    Pre-fail  Always       -       701996343
  9 Power_On_Hours          0x0032   043   043   000    Old_age   Always       -       50388
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       208
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   098   000    Old_age   Always       -       4295032861
189 High_Fly_Writes         0x003a   001   001   000    Old_age   Always       -       1384
190 Airflow_Temperature_Cel 0x0022   066   046   045    Old_age   Always       -       34 (Min/Max 25/36)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       166
193 Load_Cycle_Count        0x0032   096   096   000    Old_age   Always       -       8419
194 Temperature_Celsius     0x0022   034   054   000    Old_age   Always       -       34 (0 14 0 0 0)
195 Hardware_ECC_Recovered  0x001a   009   003   000    Old_age   Always       -       1039168
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       35189 (212 188 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2033070110
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1158915606
No Errors Logged
# 1  Short offline       Completed without error       00%     49838         -
# 2  Short offline       Completed without error       00%     49814         -
# 3  Short offline       Completed without error       00%     49790         -
# 4  Short offline       Completed without error       00%     49769         -
# 5  Short offline       Completed without error       00%     49738         -
# 6  Short offline       Completed without error       00%     49705         -
# 7  Short offline       Completed without error       00%     49685         -
# 8  Short offline       Completed without error       00%     49662         -
# 9  Short offline       Completed without error       00%     49623         -
#10  Short offline       Completed without error       00%     49587         -
#11  Short offline       Completed without error       00%     49562         -
#12  Short offline       Completed without error       00%     49538         -
#13  Short offline       Completed without error       00%     49514         -
#14  Short offline       Completed without error       00%     49490         -
#15  Short offline       Completed without error       00%     49435         -
#16  Short offline       Completed without error       00%     49319         -
#17  Short offline       Completed without error       00%     49235         -
#18  Short offline       Completed without error       00%     49151         -
#19  Short offline       Completed without error       00%     49074         -
#20  Short offline       Completed without error       00%     48999         -
#21  Short offline       Completed without error       00%     48937         -
[root@nas02] ~#
Bidule0hm
By full hardware list I wanted to say the full list, not just the CPU and RAM. What's the MB, PSU, ...? is there an HBA?, etc...
I don't see anything wrong with those drives but you didn't setup long SMART tests so I can't be sure. I recommend to launch a long test manually on each drive, wait for the end, and then post the output of smartctl again.
NB: 57 kh is more than 6.5 years. It's remarkable because the drives don't last more than 4-5 years usually. It also means the drives are probably close to the end of their life.
