Importing from omv
gribbler
I went and tried out omv for a few months mostly just to check it out - and now I'm back. I am trying to import the pool and I see it's showing as unavail
What are the suggestions to proceed here? Thanks.
zpool import
pool: sevens
state: UNAVAIL
status: The pool was last accessed by another system.
action: The pool cannot be imported due to damaged devices or data.
see: http://illumos.org/msg/ZFS-8000-EY
sevens UNAVAIL unsupported feature(s)
mirror-0 ONLINE
gpt/zfs-f259b8c9695d7d41 ONLINE
ada3p1 ONLINE
mirror-1 ONLINE
ada0p1 ONLINE
ada2p1 ONLINE
raidz1-2 ONLINE
gpt/zfs-1d34e969463c2a81 ONLINE
da1p1 ONLINE
gptid/cea4dc2d-fb08-4b46-a42b-9869fecdde81 ONLINE
da3p1 ONLINE
da4p1 ONLINE
da5p1 ONLINE
da6p1 ONLINE
gptid/dfdcad41-1e7c-7548-9bbb-29fcf270e3f1 ONLINE
gribbler
This pool uses the following feature(s) not supported by this system:
org.zfsonlinux:userobj_accounting (User/Group object accounting.)
All unsupported features are only required for writing to the pool.
The pool can be imported using '-o readonly=on'.
all of da* is an external das that were added recently and I grew the original pool under omv
all ada* are internal drives that were part of the original pool, there's 2 8tb+4tb mirror sets, that was the initial pool.
Would I be able to import one of the mirror sets, one disk at a time, then recreate the mirror?
Unfortunately, since you updated the pool with feature flags not yet supported in FreeNAS, you will only be able to mount the pool as read-only.
Other than that, you'll need to back up, destroy, re-create and restore data to your pool.
gribbler
I figured, thanks. That's ok, that's what backups are for right?
I wish there ISP had finished their upgrades before covageddon, sucking 10tb over 50Mbps will suck. :)
Thanks again for your help
