Importing an existing pool
balanga
I'm trying to import an existing pool following the instructions here:-
Select Import Existing Pool and click NEXT.
When selecting Import an existing pool, the Create new pool rather than Import an existing pool becomes highlighted... but anyhow click NEXT
The wizard asks if the pool has legacy GELI encryption.
Select No, continue with import and click NEXT.
Unable to select No. The only available option is Yes... but anyhow click NEXT
TrueNAS detects any pools that are present but unconnected.
No pool detected and no opportunity to enter name of existing pool
Choose the ZFS pool to import and click NEXT.
Review the Pool Import Summary and click IMPORT.
I know I have a pool called nas because I ran zpool import -f -R /mnt nas and managed to mount my nas pool on /mnt, but I can't find any way to import it via the GUI.
What have I overlooked?
You're nearly there...
You will first need to re-import the pool to correct the mountpoint.
zpool export nas
zpool import -f -R /mnt/nas nas
zpool export nas
Then import with the GUI.
no1ninja
zpool export nas
zpool export nas
Please help me.... I need to do this, but entering the above into shell, just gave me errors. How do I do this?
I have zfs partition that has imported fine, but can't do anything with it because the system complains about anything i try is not in its mount point
My trueNAS shell does not understand the above commands
Can you be a bit more specific about what happens when you run:
zpool status
zfs list
