Import encrypted volume into 9.10.2
BlairEL
Hiya,
I had a setup in Corral and after finding out its dead, I have reverted back to 9.10. I had a disk with encryption on the Corral setup, I know the passphrase but do not have the encryption key file, and the wizard will not let me progress with out it.
Any suggestions? I am okay to import the volume via the CLI but I am unsure of the commands
Vito Reiter
Wise in the Ways of Science
Unless you're a company that is REQUIRED to follow compliance, never encrypt volumes.
BlairEL
Can you still boot into the Corral installation that you had?
I can reinstall corrall I assume and import the volume there?
Or will I still need that key file? I had not needed it before when working only within corral, I just entered the paraphrase.
No, you will need the key. As I wrote above, if you don't have, and can't get, the key, your data is gone. That's kind of the point of encryption.
BlairEL
Okay.
I had assumed the passphrase was enough.
Thanks for the info
Stux
Is the passphrase used to decrypt the keyfile?
SweetAndLow
Sweet'NASty
Yes.
Just like the lock on a door, you need the key to get in. And the password is like a lock box that prevents someone from walking by and just opening the door with the key.
