masru
- Aug 9, 2020
this is more a "Should this work? Is this feature ready or should I file a bug?" question, not so much a "how do I get the files copied?" question.
I run a new non-production system with TrueNAS-SCALE-21.08-BETA.1. I try to import a 4TB NTFS drive, target is a (temporary scratch) pool which consists of three striped disks of different size, 20TB in total. From there the content will be copied to the final pools later.
I tried "import disks" twice yesterday and tonight. After roughly 1.5TB the job stops. Checking the files in the destination folders it seems the job failed at the same point both times.
The task manager history states this and has a red warning sign in both entries:
Is there another place where I can find out what went wrong? And should this work? Is this feature ready or should I file a bug?
Regards,
Martin
pool.import_disk Stopped: 2021-09-26 05:01:13 pool.import_disk Stopped: 2021-09-25 20:21:08
Regards,
Martin
