BUILD [Ignore] RAM Recommendation
brando56894
I actually realized I had listed the wrong motherboard, I didn't think I needed SO-DIMM so I no longer have a problem
BigDave
FreeNAS Enthusiast
I have the same board that is in the FreeNAS Mini (A1SAi-2750F) and it says it supports up to four 16 GB DDR3 1600MHz 204 pin SO-DIMM ECC modules, but the largest that I can find that matches all of that criteria is 8 GB SO-DIMMs. Can anyone give me any recommendations?
The 16GB sticks are rare, best to go with the eights for now...
Newegg has this 8GB stick, or you could look at the crucial website recommended memory list for your board here.
Oh, I lied :oops:
Here they are...
brando56894
Ouch those babies are expensive. I actually just realized that I posted the wrong motherboard hahaha I thought it was odd when it said I needed SO-DIMM RAM! I actually need 240 pin DIMMs so I no longer should have an issue. Thanks though!
