ICMP UDP Port 389 Unreachable
nathanw
Hi all,
Brand new to TrueNAS/FreeBSD, moderately experienced Ubuntu user.
If I run
cat /var/log/messages
I see the following message repeated
Jun 5 <time> truenas kernel: Limiting imcp unreach response from xxxx to 200 packets/sec
Running
tcpdump -ni igb0 "icmp"
returns thousands of iterations of
<time> IP 192.168.0.2 > randomexternalip: ICMP 192.168.0.2 udp port 389 unreachable, length 87
I'm completely stumped here. From what I know, port 389 is used for LDAP.
I'm aware I can hide these messages from the logs, but how do I stop this error?
nathanw
Figured it out.
Running
ping google.com
resulted in host name not found errors indiciating a DNS issue as
ping 8.8.8.8/CODE] worked correctly.
Turns out the Network Global Configuration settings for default gateway hadn't saved properly.
After I added the gateway details in /etc/resolv.conf the messages stopped.
Restarted, naturally the additions to resolv.conf were removed.
To fix I:
Removed the default gateway setting in Gloabl Configuration and pressed save.
Re-added the default gateway.
