IBM SERVERAID M1015 CROSS FLASHING TO A LSI9211-8I Hard Drive Issue
rkwallace
I successfully flashed both my M1015 to LSI9211-8i-it. I used firmware v.20 and installed the driver v.20 to by /boot/kernel. All warnings are cleared. I also ensured both cards had a different number "boot order" however each card only registers 4 hard drives whereas I have 8 connected to each card. I'm sure this is just a minor problem I may have overlooked but maybe somebody can save me some time. Suggestions?
Robin
P.S. I'm like 24 hours noob into the freenas stuff so be easy on me
Does FreeNAS see all drives?
If so, not a problem. If you want to fix it, try the following:
  • make sure you have the right version of the BIOS extension ROM
  • Try the UEFI version of the extension ROM instead
  • just get rid of the ROM
rkwallace
I'm gonna try this now, thank you.
rkwallace
BIOS Version and extension is the same, I cannot try UEFI because my motherboard doesn't support this, however I'm going to crossflash again without ROM.
UPDATE: This didn't work, thanks for the suggestions.
rkwallace
I know the problem has to do with my cross flash of the IBM ServerRAID M1015. I just need to know where I went wrong. Maybe I just used the wrong firmware.
gpsguy
Active Member
Did you flash both the cards without the ROM?
If you try each of the cards, one at a time, do they see all 8 drives?
rkwallace
Yes, I tried them one at a time. With, without BIOS and IR. I think either I have defective cards or cables. I purchased the cards recently on Ebay and rolled the dice on this one.
rkwallace
Cross flashed back to original firmware, still only sees 4 hard drives. It's bad cards.
Fuganater
Just buy 9211-8i cards. Upgrading them is super easy.
jgreco
Resident Grinch
The 9211-8i's cost about twice as much, which is a showstopper for many of these guys.
Two bad cards? That's odd. Are you sure all the cables are working properly?
Fuganater
Cheapest M1015 on Ebay is $85. I'd say the extra $10 is well worth it.
BigDave
FreeNAS Enthusiast
BigDave
FreeNAS Enthusiast
I assume that's the order in which the extension ROMs are loaded.
Would that apply if you were booting from a drive on one, of say, two controller cards?
Just trying to learn from you Eric, you always give me these pearls of wisdom and I've
started writing them down. NOT kidding :)
Yeah, it would determine the boot priority.
I'm not sure about the details (I've never written a BIOS), but the extension ROM has to register the card to provide boot services. Then the boot devices (built-in and cards) are called in order.
I've started writing them down. NOT kidding :)
Well, that's a surprise. :p
rkwallace
^^^^^^^^^ Yes to this!
Is it possible you flashed with the 4i firmware by mistake, I don't even know if this
is possible.
Why did you need to "install" the driver :confused:
I'm confused by this as well...
I used the correct firmware but I returned the cards and found actual LSI9211-8i cards for the same price. So I bought the originals. I assume the person I purchased the cards for did a firmware update and maybe screwed something up.
I installed the drivers so I wouldn't get the version errors. I matched the firmware to the drivers in FreeNAS, it worked.
esamett
