I do not know how to create a pol with an internal disk in my pc
didiersee
I do not know how to create a volume with an internal disk in my pc becauseit does not appear in the list of disks when I want to create the pol but I see it in the list of system disks . Help me please?
Alecmascot
Did you install TrueNAS to that disk ?
If you did then you cannot use that disk in a pool.
Hellione
provide more info. controller,disk type, system.... otherwise it´s going to be a 15 page guessing thread
didiersee
here you are
and
didiersee
Yes it is by following these videos that I installed and configured Truenas and I even saw several some in French and others in English but I did not find a solution to my problem. I had much easier to configure my raspberry PI4 in NAS than truenas.
didiersee
Hello I wanted to reinstall truenas but I can no longer do it with a usb key or with a DVD. Here is the error message I got:
