HTTPS Web GUI Broken after reinstall
SweetAndLow
Sweet'NASty
I did a reinstall of TrueNAS Core 13.0-U5.3 and after uploading my config.db file I got an alert and it seems like accessing the https version of the gui isn't working.
Web UI HTTPS certificate setup failed.​
2023-09-27 21:33:44 (America/Los_Angeles)
I still have the default freenas_default certificate from iXsystems
Everything seems to look normal but there is clearly something missing. I know there is a workaround by adding another CA and creating my own self signed certificate but I would prefer if it was working like it was out of the box, one less thing I have to maintain or remember.
What maybe seems odd to me is the freenas_default doesn't have a private key anymore.
SweetAndLow
Sweet'NASty
OK i have loaded an older config file I have that was the .tar version which has the seed value and the https gui seems to be working. I'm doing this in a test vm not on the live system.
I'm going to see if i can just edit the live system db and add the private key.
