Https redirect locks the Webgui
daquirm3
I’ve set up Freenas to redirect automatically from Http to https through webgui, but from now on my webgui is not accessible, how can I revert this setting?
freenas.local 11.3-RELEASE-p9
Best regards
Samuel Tai
From the shell, run midclt call system.general.update "ui_httpsredirect":false.
daquirm3
Thanks for reply Samuel, it didn‘t go as expected:
root@freenas:~ # midclt call system.general.update "ui_httpsredirect":false
[general_settings] A dict was expected
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
    io_thread=False)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1084, in _call
    return await methodobj(*args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/service.py", line 301, in update
    f'{self._config.namespace}.update', self, self.do_update, [data]
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 960, in nf
    args, kwargs = clean_and_validate_args(args, kwargs)
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 918, in clean_and_validate_args
    value = attr.clean(args[args_index + i])
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 583, in clean
    raise Error(self.name, 'A dict was expected')
middlewared.schema.Error: [general_settings] A dict was expected
daquirm3
It still redirects, but it doesn’t work...
catherineva11e
Is that iOS? do you access to a non apple device? Apple security changed how it handles HSTS (http strict transport security).
Samuel Tai
Apologies, you'll have to do this via the REST API. Run this from shell: curl --basic -u root -k -X PUT "https://<your FreeNAS IP>/api/v2.0/system/general" -H "accept: */*" -H "Content-Type: application/json" -d '{"ui_httpsredirect":false}'. I verified this works on my own system.
daquirm3
Thank you for help, the problem is indeed with iOS device only, I tried to access it through Firefox/Ubuntu and the Webgui is accessible again. As I use ipad exclusively to manage everything now, it‘s kind of pitty, that FreeNAS doesn’t work with that. The API call works well, I guess service nginx restart is needed to apply the changes?
Samuel Tai
No, the API call hooks the FreeNAS middleware, which automatically restarts the HTTP and django services after applying this change.
