What Make/Model HP SAS Expander.. I just discovered (yesterday?) that Expanders need to be driven by an HBA... So perhaps that is the issue?
Can you elaborate on how this is installed and setup?
For reference, I will direct you to this Thread.
I *don't think* that is the way it works, I think that you still need an HBA; but will defer to others (like @Ericloewe)
That'd be very nice. If you wanted the drives to talk to each other (and if they could).I will try to be more specific...
First of here is the card... HP 24 Bay PCI-E SAS Expander Card 468.406-B21 487.738 to 001
I have this card installed in a pci-e x16 slot. With 6s 8087 cables connected to the backplanes of this case https://www.xcase.co.uk/collections...lue-rm-424-24-hotswap-bays?variant=9205909957
AM SUCH A NOOB...
Been reading about expanders and hbas...
to make this simple
backplane to HBA to optional expander?
Nah, I didn't know until yesterday myself... :)AM SUCH A NOOB...
No.backplane to HBA to optional expander?
Code:Host ---> HBA ---> Expander ---> HDD ---> HDD ---------------------> HDD
Hi i am trying to solve my noob issues...No.
The expander is like a network switch. You just use it to run more than four drives off a single SFF-8087 connector from an HBA.
Code:Code:Host ---> HBA ---> Expander ---> HDD ---> HDD ---------------------> HDD
Something of the sort, but that's a poor choice. You want an LSI HBA.Hi i am trying to solve my noob issues...
IF i connect my sas expander to this http://storage.microsemi.com/en-us/support/raid/sas_raid/sas-6405e/ would that make it possible to utililize the ports on the sas expander card?
I only have One pci e 16x the other ones are pci or pci e 1x. So i cant use any lsi card i have found.... They are atleast 4x.
I just want to be able to connect my 24 drives... So any other solution am all ears.
What's wrong with putting the LSI in the x16 slot?
Normally a sas expander card does not need to be in a PCIe slot and they can be powered using an alternative method.
Put the LSI HBA in the x16 slot.
Can it be powered by the sff8087 cable?
here is my cardAll the ones I've seen have a mloex or some other connector to supply power.
No chance in hell.Can it be powered by the sff8087 cable?
Yeah, that's poor design.here is my card
http://www.ebay.com/itm/HP-24-Bay-SAS-Expander-Card-487738-001-468405-002-New-Bulk-/141853886808
cant see how this card will get power from anything but pci-e...?
