Hi!
I run and embedded version. Easy install and work fine!
I needed to customize some config files as adding aliases, adding a termcap entry to support my ordinosaur tandy model 200 used as a terminal and few others things.
I first test adding aliases. But I do not understand why they are not saved? At reboot the old config files are set-up in their genuine form.
Does it means that to modify them I have to re-compile a private version? and create a new image which could be logical since we load it into a ramFS, isn'it?
If I'm not wrong could some one give me some info to do it under BSD as things are a bit differents under this system?
thanks.
thanks.
