stitch
- Jan 7, 2017
This is based on the earlier work of airflow in this thread. Because of the security concerns with exposing your NAS to the whole world even if only via jail, the better and more secure option is to use DNS verification.
The Acme.sh script by neilpang gives you Let's Encrypt certificate generation and supports performing DNS verification (with the option to automatically update your personal domain's DNS provider via API-where available) to verify you own the DNS and that they can issue the certificate.
So, this is a little involved but I believe it would survive any updates to FreeNAS. I've done this entirely on FreeNAS 11.1 via a combination of SSH and the new GUI. You can probably do it via the Shell menu too.
Step 1. Get a certificate onto the system
Basically, you need to get a certificate that FreeNAS will allow for use as an HTTPS certificate so that there is an entry in the configuration that we can "pretend to be". In my case, I created a CA, then generated the certificate from there.
Step 2. Set up an iocage jail and call it "acme".
Step 3. Ensure that you configure your jail with an IPv4 address, e.g. if using a LAGG, it would read "LAGG0|172.16.10.26" (without the quotes of course).
Step 4. Stop and start the jail
Step 5. Via SSH, once in type the following
Step 6. Verify that your jail does have an IP using the ifconfig command
Step 7. Install pkg
Step 8. Install the packages we need to complete the rest (I apologize, I like vim)
Step 9. Swap over to bash
Step 10. Download and install acme
Step 11. Modify the first line of the resulting bash script that was downloaded to use the jail's bash
Step 12. Export your Dynamic DNS API credentials based on the instructions here. I'm assuming you are using one of the support APIs.
Step 12. Generate your certificates
Step 13. Exit the jail
Step 14. Make a directory on one of your storage volumes for your certificates to be symbolicly linked. Basically, we're going to create symbolic links in a future step to match the naming of the certificate we generated in step 1.
Step 15. Determine the names of the certificates we created in step 1 so we know what to name our symbolic links
Step 16. Create our symbolic links to our generated certificates
Step 17. Get your GUI on- Log into your FreeNAS server's UI
Step 17a. Set your tunable
Go to System -> Tunables -> Click "Add Tunable". Set the Variable to "SSLDIR" without quotes. Set the Value to "/mnt/myvolumename/certs/" without quotes. Please make sure it is set to enabled.
Step 17b. HTTPS
Go to System -> General -> GUI Protocol and set it HTTP+HTTPS. Set the Certificate to the one you created in step 1.
FOR THE LOVE OF ALL THAT IS GOOD: WebGUI HTTP -> HTTPS Redirect SHOULD BE UNCHECKED!!
Step 17c. CRON Task to restart
Go to Tasks -> Cron Jobs
Users: Root
Command: service nginx restart
Set the Minute to Each Selected and choose 5
Set the Hour to Each Selected and choose 0
Set the Day of the Month to Each Selected and 1
Set the Month to each month
Do not set day of the week
Hit Save
Step 18. Go back to SSH and console into the jail again
Step 19. Set your crontab to renew the certificate each month
Paste in the following:
This will renew the certificate on the 1st day of each month
Step 20. Exit the jail
Step 21. Restart Nginx
That should be it I think?
iocage console acme
Step 7. Install pkg
pkg
pkg install curl bash vim
bash
curl https://get.acme.sh | sh
#!/bin/bash # is replaced with #!/usr/local/bin/bash
.acme.sh/acme.sh --issue --dns dns_aws -d myhost.mydomain.com
exit
mkdir /mnt/myvolumename/certs
ls /etc/certificates
ln -s /mnt/iocage/jails/acme/root/root/.acme.sh/myhost.mydomain.com/fullchain.cer /mnt/myvolumename/certs/myhost.crt
ln -s /mnt/iocage/jails/acme/root/root/.acme.sh/myhost.mydomain.com/myhost.mydomain.com.key /mnt/myvolumename/certs/myhost.key
Step 17b. HTTPS
Users: Root
Hit Save
iocage console acme
crontab -e
0 0 1 * * /root/.acme.sh/acme.sh --renew --force -d myhost.mydomain.com
exit
