SOLVED How to view SMART results when no errors are detected?
spiceygas
I just setup a new pool with brand news drives, and I plan to stress them and monitor for a few weeks to make sure no problems are detected. I'm also brand new to FreeNAS, so I apologize in advance if this sounds like an amateur question.
How do I get SMART results to be emailed to me even if no errors are detected? Here's what I've done so far:
  1. Setup email under "System" and successfully delivered a test message.
  2. Scheduled a SMART task for a short test to run daily.
  3. In System > Alert Settings, set SMART Error warning level to "Info."
I never got an email that the test had run. Thumbnails below of how I did setup in steps #2 and #3.
Any suggestions what I'm doing wrong?
garm
You aren’t doing anything wrong. It’s set up as intended. If you want reports emailed there is a resource for that. Otherwise you can just set up a cron job to cycle through your drives with smartctl -a /dev/[drive] and print that to a file in an smb share or something.
spiceygas
spiceygas
Thank you.
