How to view live RAM Voltage?
polygonalsnow
I'm looking to check the current voltage being applied to my RAM. On Windows I use HWinfo64. I tried dmidecode -t 17 but it looks like those are just preconfigured values, not live ones. Is there any other option on FreeNAS to view RAM voltages?
Backstory: I've been suffering from instability on my Ryzen 1700 system for the past couple years, and just assumed it was the C-state bug that couldn't be fixed. But now, I have a Ryzen 2700 and it still suffers from instability, so I'm seeing if raising the RAM voltage from 1.2 to 1.35V helps, but I need a way to verify my RAM voltage has actually changed in the OS. The BIOS says it has but I'm not sure if I trust it, because dmidecode -t 17 returns the following:
Handle 0x0010, DMI type 17, 84 bytes
Memory Device
        Array Handle: 0x0009
        Error Information Handle: 0x000F
        Total Width: 64 bits
        Data Width: 64 bits
        Form Factor: DIMM
        Set: None
        Locator: DIMM 0
        Bank Locator: P0 CHANNEL A
        Type: DDR4
        Type Detail: Synchronous Unbuffered (Unregistered)
        Speed: 2133 MT/s
        Manufacturer: Unknown
        Serial Number: 00000000
        Asset Tag: Not Specified
        Part Number: CMK16GX4M2B3000C15
        Rank: 1
        Configured Clock Speed: 2133 MT/s
        Minimum Voltage: 1.2 V
        Maximum Voltage: 1.2 V
        Configured Voltage: 1.2 V
Handle 0x0013, DMI type 17, 84 bytes
Memory Device
        Error Information Handle: 0x0012
        Data Width: 64 bits
        Form Factor: DIMM
        Set: None
        Locator: DIMM 1
        Type: DDR4
        Speed: 2133 MT/s
        Rank: 1
Handle 0x0016, DMI type 17, 84 bytes
Memory Device
        Error Information Handle: 0x0015
        Total Width: Unknown
        Data Width: Unknown
        Size: No Module Installed
        Form Factor: Unknown
        Set: None
        Locator: DIMM 0
        Bank Locator: P0 CHANNEL B
        Type: Unknown
        Type Detail: Unknown
        Speed: Unknown
        Serial Number: Unknown
        Part Number: Unknown
        Rank: Unknown
        Configured Clock Speed: Unknown
        Minimum Voltage: Unknown
        Maximum Voltage: Unknown
        Configured Voltage: Unknown
Handle 0x0018, DMI type 17, 84 bytes
Memory Device
        Error Information Handle: 0x0017
        Data Width: Unknown
        Set: None
        Locator: DIMM 1
        Type: Unknown
        Speed: Unknown
        Rank: Unknown
Redcoat
Might this be better addressed in a FreeBSD forum given that FreeBSD forms the underpinnings for FreeNAS?
polygonalsnow
I'll do that as well. Was just wondering if anyone here had any ideas
