Hey all.
So I'm a n00b at freenas. I'm running 4X2TB HDD in RAIDZ and getting pretty bad speeds. So I did some reading and found some zfs tunables. I was just wondering how tunables work and what value goes where.
For instance I found this tunable vfs.zfs.txg.timeout="5" and how do I input that into freenas? I mean what goes into the variable, value and comment sections?
I read some stuff about changing the vm_kmem_size depending on your system but that with 64bit and freenas 8 they should be stable. Should I change it, if so what should they be?
My specs are:
CPU: Intel core 2 duo E6700 2.66Ghz
RAM: 2gig ddr2
HDD: 4X2TB in raidz
Using mobo sata controller.
Also are there any other tunables you could suggest for my system and their related values or should I just buy more ram?
Thanks in advance.
My specs are:
RAM: 2gig ddr2
HDD: 4X2TB in raidz
Thanks in advance.
