how to update NZBtoMEDIA?
Dwight Turner
getting this in the post processing log
[15:54:02] [INFO]::MAIN: Loading config from [/usr/local/share/nzbToMedia/autoProcessMedia.cfg]
[15:54:02] [INFO]::MAIN: Checking database structure...
[15:54:02] [INFO]::MAIN: Checking if git needs an update
[15:54:03] [INFO]::MAIN: There is a newer version available  (you're 30 commits behind)
Joshua Parker Ruehlig
cd /usr/local/share/nzbToMedia
git pull
Assuming you followed the steps in by blog you'd also need to set ownership
chown -R media:media /usr/local/share/nzbToMedia
Also you can set nzbToMedia to update itself, but just be ready for things break if the config changes
Dwight Turner
thanks that worked !
