Once one is at the shell level, how do I return to the console menu? In FN7 the "su" command would return to menu (which is strange, but OK I guess...), but in FN8 su has no effect (presumably since one is already root).
in the shell just type 'exit' and hit return, note if you've changed the 'shell' you may need to type 'exit' 2 or more times to return to the console menu.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
