We're rebuilding our two freenas systems to be raidz2 rather than raidz1 (FreeNAS Mini hardware). When I rebuilt the back up system, and exported the pool, several items such as periodic snapshots seem to have went away with the pool. While I can write everything down and rebuild the configs by hand, I'd much prefer to not have to do that. I'm using ZFS send/receive to move everything around as I rebuild the pools, so the paths, snapshots, etc. should all be identical when I'm done to before I started the rebuild, just the underlying pool will be a raidz2 on bigger disks.
Before I change the primary system, I'm going to temporarily move the system data set to the boot drive, and then take a backup of the config. If I restore the config after I have the pool and file systems back in place, will that get me back the tasks, etc. or am I way off base here?
Thanks!
Thanks!
