SOLVED How to fix incorrect time?
TheDubiousDubber
FreeNAS is showing the wrong time on one of my servers. Which I only noticed recently since it is causing issues with my PVR plugin. I have it set to the correct timezone, and the clock in bios is set to the proper time as well. I have no idea why it's displaying the wrong time but it remains quite a few hours off.
As of right now (10:30 CST) it is displaying 4:30 CST.
DrKK
FreeNAS Generalissimo
Is the time difference exactly the difference between Zulu (UTC) time, and local time?
TheDubiousDubber
Not sure, just ran date 2250 and it set to correct time. Hopefully that fixes it. Seems to have worked for now.
Edit:
Just checked. It is exactly 6 hours behind and CST is 6 hours from UTC
Also tried running ntpd and it kept erroring out, something about not being able to bind to socket.
DrKK
Edit:
Isn't there a question, on original install, "Is this system clock intended to represent UTC or local time?" I seem to recall that. Perhaps you answered wrong.
And also, ntpd should already be running (which is why you can't bind to the socket---it's already bound).
Try this:
[root@giskard] ~# ntpq -np
  remote  refid  st t when poll reach  delay  offset  jitter
+204.2.134.162  204.123.2.72  2 u  516 1024  357  114.729  -3.096  18.343
+108.61.73.244  18.26.4.105  2 u  714 1024  377  16.246  1.416  1.185
*108.61.56.35  128.59.0.245  2 u  513 1024  377  12.799  0.572  1.634
TheDubiousDubber
I don't recall a question like that. I quit out of the wizard half way through so perhaps that is why. I configured it manually for the most part.
Ran that command and I get this:
*69.164.201.165  130.207.244.240  2 u  58  64  377  39.722  -20.510  4.576
+204.2.134.163  44.24.199.34  3 u  2  64  377  82.609  -20.127  9.938
+104.156.99.30  164.67.62.194  2 u  37  64  377  66.132  -14.213  7.022
DrKK
OK, well that means your ntpd is running correctly, and almost certainly tracking/setting your system clock as needed.
I think your problem was a too-large offset in the clock to start with; as I said, ntpd will refuse to deal with a clock that is too insanely off. Now that you manually updated the clock, ntpd can probably take it from here.
