I recently built a brand new system, a supermicro A2SDi-8C-HLN4F with 16 gigs of memory, and a U-NAS nsc-800 case.
System works great, however I get a slowdown over night. I can still log in to the gui, but everything is so sluggish. Under the reporting I just get the page with no information. If I go to pluggins it it is extremely slow. I haven't been able to figure out why. I have worked with linux systems in the past, so I check on the /var/log/messages and I can clearly see that something happens in the mornings, between 5 and 7, not the same time every day, but during that period. If I reboot the system, it comes back perfectly, but there is no error reporting as to what could be happening. If I go under reporting in the GUI for example CPU I can see everything before the system gets sluggish to be normal, then there is no information again till I reboot, and then everything looks normal again. How can I go by diagnosing this problem. The messages log file doesn't show any information neither does the system log file. I can log in the IPMI interface, and that seems not to be affected by the GUI slowdown either.
