How to create a system
  • Thread starter Deleted member 34036
  • Start date
D
Guest
I have been trying to configure a system for our office:Please help me out.
I want to have enough redundancy:
List of Hardware's:
1. Supermicro server
2. 7200Rpm seagate disks
I am thinking to create a group with 48 x 3 TB HDD + 1 SSD for caching and 7 spare HDD in the group..kindly suggest if I am thinking in the right way. Or else kindly suggest me the best way to build a system with enough redundancy using 55 x 3TB HDD + 1 (120 GB SSD). Kindly find the system info in the attached file.
Thanks,
Sharfraj
Second, read my noob guide(link in my sig). You're going to need more than 32GB of RAM unless this is a backup-only server.
D
Guest
Thanks for kind replies.
But my doubt is if I create a single pool using 48 Hard disks from the total of 55 Hard disks (3 TB each) in RAID Z configuration and assign the left 7 more Hard disks as spare; while configuring and also add a SSD (120 GB) as cache to the pool. Will it work well and provide redundancy and take over a spare disk from the 7 spare disk; if in case a disk fails and the system remains up and running.
Using this configuration I am able to get 120 TB usable from 165 TB Raw HDD space (55x3=165 TB).
In the meantime I am going through the manuals/guides.
Thanking you once again,
regards,
Sharfraj
D
Guest
Recently i got this error when I tried wiping the disks:
Error: Failed to wipe da2: dd: /dev/da2: Operation not permitted
While wiping I get the same error on several disks
If I go to create Pools in Zvolume manager I get "Unable to GPT format the disk "da2"
Please guide me what's the problem
regards,
Sharfraj
D
Guest
The problem has been solved.
I have solved this "Unable to GPT format the disk "da2" problem. I got this error on several disks when I tried wiping. Eventually, I took out all those identified disks, connected the same disks to windows 7 system and formatted those disks in windows and created a simple volume. And before formatting, I partitioned those disks in GPT. Thats it!
When I again booted up the machine using FreeNAS, I am able to create volumes again and the error was gone.
Thanks,
