How to clear Security Run Output
mredlancelot
Hi All, I am new to the forum and new to FreeNas, I have it all set up and running and I think this is a great piece of software.
My question is: How do I clear the security Run output? I mean, I get this email every day, but it seems it always says the same, as I have just set everything up and I am learning, I restart the machine every now and then, and this message keeps telling me that the machine was shut down and up again, etc. so how can I "acknowledge" so my server doesn't keep "crying wolf".
FreeBSD 9.2-RELEASE-p12 #0 r262572+b043649
CPU: Intel(R) Pentium(R) CPU G3258 @ 3.20GHz (3199.14-MHz K8-class CPU)
real memory = 8589934592 (8192 MB)
MB: Asrock H87M Pro4
PSU: Corsair CX430
warri
It is usually cleared automatically after sending the email.
Do you reboot your machine daily? Then you will get emails every day.
Can you post the relevant section of the security log?
mredlancelot
Hi Warri, thank you for the quick response.
I have restarted it at least once per day in the last couple of days... so perhaps just I'll wait couple of days and see if it goes away.
in a related issue, is there a way to add some info to the email, for example, I'd like to see the times for each line
the log looks like this:
> vboxdrv: fAsync=0 offMin=0x357 offMax=0x1397
> bridge0: Ethernet address: 02:fe:4a:c8:9c:00
> bridge0: link state changed to UP
> em0: promiscuous mode enabled
> epair0a: Ethernet address: 02:12:11:00:07:0a
> epair0b: Ethernet address: 02:12:11:00:08:0b
> epair0a: link state changed to UP
> epair0b: link state changed to UP
> epair0a: promiscuous mode enabled
> em0: link state changed to DOWN
> ng_ether_ifnet_arrival_event: can't re-name node epair0b
> em0: link state changed to UP
> epair1a: Ethernet address: 02:91:45:00:08:0a
> epair1b: Ethernet address: 02:91:45:00:09:0b
> epair1a: link state changed to UP
> epair1b: link state changed to UP
> epair1a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair1b
> epair2a: Ethernet address: 02:96:54:00:09:0a
> epair2b: Ethernet address: 02:96:54:00:0a:0b
> epair2a: link state changed to UP
> epair2b: link state changed to UP
> epair2a: promiscuous mode enabled
> ng_ether_ifnet_arrival_event: can't re-name node epair2b
> epair0a: link state changed to DOWN
> epair0b: link state changed to DOWN
> epair1a: link state changed to DOWN
> epair1b: link state changed to DOWN
> epair2a: link state changed to DOWN
> epair2b: link state changed to DOWN
> bridge0: link state changed to DOWN
> em0: promiscuous mode disabled
> Waiting (max 60 seconds) for system process `vnlru' to stop...done
> Waiting (max 60 seconds) for system process `bufdaemon' to stop...done
> Waiting (max 60 seconds) for system process `syncer' to stop...
> Syncing disks, vnodes remaining...0 0 0 0 0 done
> All buffers synced.
> Timecounter "TSC-low" frequency 1599569302 Hz quality 1000
> ugen0.4: <vendor 0x05e3> at usbus0
> uhub4: <vendor 0x05e3 USB2.0 Hub, class 9/0, rev 2.00/7.02, addr 4> on usbus0
> Root mount waiting for: usbus0
> uhub4: 4 ports with 4 removable, bus powered
> ugen0.5: <vendor 0x1241> at usbus0
> ukbd0: <vendor 0x1241 USB Keyboard, class 0/0, rev 1.10/2.90, addr 5> on usbus0
> uhid0: <vendor 0x1241 USB Keyboard, class 0/0, rev 1.10/2.90, addr 5> on usbus0
> vboxdrv: fAsync=0 offMin=0x33d offMax=0xd37
> epair0a: Ethernet address: 02:d4:e4:00:07:0a
> epair0b: Ethernet address: 02:d4:e4:00:08:0b
> epair1a: Ethernet address: 02:d2:51:00:08:0a
> epair1b: Ethernet address: 02:d2:51:00:09:0b
> epair2a: Ethernet address: 02:ab:99:00:09:0a
> epair2b: Ethernet address: 02:ab:99:00:0a:0b
> Waiting (max 60 seconds) for system process `syncer' to stop...Syncing disks, vnodes remaining...2 2 1 1 1 0 0 0 0 0 done
> All buffers synced.
> Copyright (c) 1992-2013 The FreeBSD Project.
> Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
>       The Regents of the University of California. All rights reserved.
> FreeBSD is a registered trademark of The FreeBSD Foundation.
> FreeBSD 9.2-RELEASE-p12 #0 r262572+b043649: Sun Sep 28 23:03:31 PDT 2014
>     root@build3.ixsystems.com:/tank/home/jkh/build/921/freenas/os-base/amd64/fusion/jkh/921/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
> gcc version 4.2.1 20070831 patched [FreeBSD]
>   Origin = "GenuineIntel"  Id = 0x306c3  Family = 0x6  Model = 0x3c  Stepping = 3
>   Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
>   Features2=0x4ddaebbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,<b11>,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,XSAVE,OSXSAVE,RDRAND>
>   AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
>   AMD Features2=0x21<LAHF,ABM>
>   Standard Extended Features=0x2603<GSFSBASE,TSCADJ,ENHMOVSB,INVPCID>
>   TSC: P-state invariant, performance statistics
> avail memory = 7889338368 (7523 MB)
> Event timer "LAPIC" quality 600
> ACPI APIC Table: <ALASKA A M I>
> FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
> FreeBSD/SMP: 1 package(s) x 2 core(s)
>  cpu0 (BSP): APIC ID:  0
>  cpu1 (AP): APIC ID:  2
> WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
> ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
> ioapic0 <Version 2.0> irqs 0-23 on motherboard
> kbd1 at kbdmux0
> cryptosoft0: <software crypto> on motherboard
> aesni0: No AESNI support.
> padlock0: No ACE support.
> acpi0: <ALASKA A M I> on motherboard
> acpi0: Power Button (fixed)
> acpi0: reservation of 67, 1 (4) failed
> cpu0: <ACPI CPU> on acpi0
> cpu1: <ACPI CPU> on acpi0
> hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
> Timecounter "HPET" frequency 14318180 Hz quality 950
> Event timer "HPET" frequency 14318180 Hz quality 550
> Event timer "HPET1" frequency 14318180 Hz quality 440
> Event timer "HPET2" frequency 14318180 Hz quality 440
> Event timer "HPET3" frequency 14318180 Hz quality 440
> Event timer "HPET4" frequency 14318180 Hz quality 440
> Event timer "HPET5" frequency 14318180 Hz quality 440
> Event timer "HPET6" frequency 14318180 Hz quality 440
> atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
> atrtc0: Warning: Couldn't map I/O.
> Event timer "RTC" frequency 32768 Hz quality 0
> attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
> Timecounter "i8254" frequency 1193182 Hz quality 0
> Event timer "i8254" frequency 1193182 Hz quality 100
> Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
> acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
> pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
> pci0: <ACPI PCI bus> on pcib0
> vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf0000000-0xf03fffff,0xe0000000-0xefffffff irq 16 at device 2.0 on pci0
> pci0: <multimedia, HDA> at device 3.0 (no driver attached)
> pci0: <serial bus, USB> at device 20.0 (no driver attached)
> pci0: <simple comms> at device 22.0 (no driver attached)
> em0: <Intel(R) PRO/1000 Network Connection 7.3.8> port 0xf080-0xf09f mem 0xf0400000-0xf041ffff,0xf043d000-0xf043dfff irq 20 at device 25.0 on pci0
> em0: Using an MSI interrupt
> em0: Ethernet address: d0:50:99:20:c3:c2
> ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf043c000-0xf043c3ff irq 16 at device 26.0 on pci0
> usbus0: EHCI version 1.0
> usbus0 on ehci0
> pci0: <multimedia, HDA> at device 27.0 (no driver attached)
> pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
> pci1: <ACPI PCI bus> on pcib1
> pcib2: <ACPI PCI-PCI bridge> at device 28.3 on pci0
> pci2: <ACPI PCI bus> on pcib2
> pcib3: <ACPI PCI-PCI bridge> irq 19 at device 0.0 on pci2
> pci3: <ACPI PCI bus> on pcib3
> ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf043b000-0xf043b3ff irq 23 at device 29.0 on pci0
> usbus1: EHCI version 1.0
> usbus1 on ehci1
> isab0: <PCI-ISA bridge> at device 31.0 on pci0
> isa0: <ISA bus> on isab0
> ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf0d0-0xf0d7,0xf0c0-0xf0c3,0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf060-0xf07f mem 0xf043a000-0xf043a7ff irq 19 at device 31.2 on pci0
> ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
> ahcich0: <AHCI channel> at channel 0 on ahci0
> ahcich1: <AHCI channel> at channel 1 on ahci0
> ahcich2: <AHCI channel> at channel 2 on ahci0
> pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
> acpi_button0: <Power Button> on acpi0
> uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
> sc0: <System console> at flags 0x100 on isa0
> sc0: VGA <16 virtual consoles, flags=0x300>
> vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
> atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
> atkbd0: <AT Keyboard> irq 1 on atkbdc0
> kbd0 at atkbd0
> atkbd0: [GIANT-LOCKED]
> wbwd0: DevID 0xc3 DevRev 0x33, will not attach, please report this.
> coretemp0: <CPU On-Die Thermal Sensors> on cpu0
> est0: <Enhanced SpeedStep Frequency Control> on cpu0
> p4tcc0: <CPU Frequency Thermal Control> on cpu0
> coretemp1: <CPU On-Die Thermal Sensors> on cpu1
> est1: <Enhanced SpeedStep Frequency Control> on cpu1
> p4tcc1: <CPU Frequency Thermal Control> on cpu1
> Timecounters tick every 1.000 msec
> ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
> DUMMYNET 0xfffffe000412ccc0 with IPv6 initialized (100409)
> load_dn_sched dn_sched RR loaded
> load_dn_sched dn_sched WF2Q+ loaded
> load_dn_sched dn_sched FIFO loaded
> load_dn_sched dn_sched PRIO loaded
> load_dn_sched dn_sched QFQ loaded
> usbus0: 480Mbps High Speed USB v2.0
> usbus1: 480Mbps High Speed USB v2.0
> ugen0.1: <Intel> at usbus0
> uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
> ugen1.1: <Intel> at usbus1
> uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
> ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
> ada0: <WDC WD20EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
> ada0: Serial Number WD-WCC4M9YLC2TT
> ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
> ada0: Command Queueing enabled
> ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
> ada0: quirks=0x1<4K>
> ada0: Previously was known as ad4
> ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
> ada1: <WDC WD20EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
> ada1: Serial Number WD-WCC4MP52TP20
> ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
> ada1: Command Queueing enabled
> ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
> ada1: quirks=0x1<4K>
> ada1: Previously was known as ad6
> ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
> ada2: <WDC WD20EFRX-68EUZN0 80.00A80> ATA-9 SATA 3.x device
> ada2: Serial Number WD-WCC4M8X074LX
> ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
> ada2: Command Queueing enabled
> ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
> ada2: quirks=0x1<4K>
> ada2: Previously was known as ad8
> SMP: AP CPU #1 Launched!
> Timecounter "TSC-low" frequency 1599572278 Hz quality 1000
> Root mount waiting for: usbus1 usbus0
> uhub0: 2 ports with 2 removable, self powered
> uhub1: 2 ports with 2 removable, self powered
> ugen0.2: <vendor 0x8087> at usbus0
> uhub2: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus0
> ugen1.2: <vendor 0x8087> at usbus1
> uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus1
> uhub2: 6 ports with 6 removable, self powered
> uhub3: 8 ports with 8 removable, self powered
> ugen0.3: <Kingston> at usbus0
> umass0: <Kingston DataTraveler 2.0, class 0/0, rev 2.00/1.00, addr 3> on usbus0
> umass0:  SCSI over Bulk-Only; quirks = 0x4100
> umass0:4:0:-1: Attached to scbus4
> da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
> da0: <Kingston DataTraveler 2.0 PMAP> Removable Direct Access SCSI-4 device
> da0: Serial Number 60A44C413984BE11597000B7
> da0: 40.000MB/s transfers
> da0: 14899MB (30514176 512 byte sectors: 255H 63S/T 1899C)
> da0: quirks=0x3<NO_SYNC_CACHE,NO_6_BYTE>
> kbd2 at ukbd0
> Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
> GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
> ZFS filesystem version: 5
> ZFS storage pool version: features support (5000)
> GEOM_ELI: Device ada0p1.eli created.
> GEOM_ELI: Encryption: AES-XTS 256
> GEOM_ELI:     Crypto: software
> GEOM_ELI: Device ada1p1.eli created.
> GEOM_ELI: Device ada2p1.eli created.
> vboxdrv: fAsync=0 offMin=0x346 offMax=0xe15
> epair0a: Ethernet address: 02:0b:c2:00:07:0a
> epair0b: Ethernet address: 02:0b:c2:00:08:0b
> epair1a: Ethernet address: 02:74:4c:00:08:0a
> epair1b: Ethernet address: 02:74:4c:00:09:0b
> epair2a: Ethernet address: 02:e2:3f:00:09:0a
> epair2b: Ethernet address: 02:e2:3f:00:0a:0b
warri
Looks like a normal security email related to reboots. They should disappear as soon as you stop restarting the box :)
Currently there is no way to customize the security email or the daily run email (which is only sent if there is something wrong).
However, you can trigger emails yourself by means of a shell script and cronjobs. This requires some knowledge about shell scripting, though.
If you feel that customizable emails are an important feature, you can open a feature request at https://bugs.freenas.org
mredlancelot
Thank you, I'll get more comfortable with the system before I start making suggestion on how to make it better.;)
