i setup a SMB(Windows shared folder),and a FTP server
so i want to know how to backup those things to a thumb drive or a external drive
The freenas software running on a baremetal computer
SPEC:
intel core i 7
24GB RAM
1*5TB HDD
4USB ports
You'd be much better off configuring a pool with some redundancy first. Then you can consider a backup strategy; a search here will come up with many suggestions. Check out the Resources section too.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
