How to (1Dataset)x(1VM)
vitaprimo
I was about to move some VMs from Zvols to Datasets (iSCSI > NFS) when I realized I don't have any NFS shares--just in case there's something new to learn I got myself to the docu and this caught my eye:
I had no plans on deduplicating anything but am I curious about that. How does that work? Do I have to manually create a dataset per VM? Would that also mean, exporting the dataset, import the datastore each time?? Or…is it automated like vVols/vSAN? I sounds exactly like either of those, kinda--vSAN would be distributed.
If it is automated, this have be the best feature of FreeNAS hands down.
Samuel Tai
@Stilez has a resource just for your questions:
However, this is a very RAM-intensive feature, and you shouldn't consider it unless you have at least 256 GB of RAM.
What the tip refers to is creating a master dataset, snapshotting the master, and cloning the snapshot to provide to each VM as its own NFS share.
