StandardAtomic
- Nov 20, 2011
On my setup I have a whole variety of disks and a few attached to the system via SATA and some via USB.
To test performance I setup my zpools as I'd like to deploy and load them up with spare data I was going to throw away into the bit bucket.
With a bunch of data on the disks I ssh into the host and initiate a "zpool scrub <poolname>" for each pool. Then I run "zpool iostat 5" and watch.
Here is a snapshot of what I received:
- fgh is an older SATA 1.x drive off of it's own controller.
- onetbstripe is a pair of 1tb drives striped. One is off of USB and the other off the motherboard SATA.
- raptor is a pair of 15K RPM raptors off of the motherboard SATA controllers.
- twotbdisk is a new SATA 1.x 2 TB disk off the motherboard.
Doing this will give you a really good idea of what the max read performance of your zpools. In my experience with ZFS on Solaris hosts with high end storage, a scrub operation will max out those storage devices.
An additional thing is you can initiate a zpool scrub to help load up your freenas box during your acceptance testing before deployment and putting valuable data on it. During any burn in testing, just fire off scrubs at regular intervals.
I would not do scrubs on any SSD drives because of the wear.
Enjoy!
capacity operations bandwidth pool used avail read write read write ---------- ----- ----- ----- ----- ----- ----- fgh 7.57G 288G 590 0 73.6M 0 onetbstripe 15.1G 1.80T 390 0 48.6M 0 raptor 36.1G 238G 1.71K 13 218M 19.3K twotbdisk 7.57G 1.81T 923 11 115M 14.9K ---------- ----- ----- ----- ----- ----- ----- fgh 7.57G 288G 575 0 71.6M 0 onetbstripe 15.1G 1.80T 397 0 49.4M 0 raptor 36.1G 238G 1.71K 0 217M 0 twotbdisk 7.57G 1.81T 944 0 118M 0
Enjoy!
