How do I validate replication data?
mortis2600
Hello everyone,
I setup a replication task on my FreeNAS server (Alpha) to replicate to a secondary FreeNAS server (beta).
It performs the replication process, but I don't see where the files are located on the beta server.
Target pool/dataset is: Replication/Backup.
How do I validate data myself?
Chris Moore
More description is needed here. How did you make the copy? Two different servers or two pools within the same server?
mortis2600
As mentioned in my OP, I am doing a replication task from one FreeNAS server to another.
D
dlavigne
Guest
Were you able to resolve this? If not, we need many more details as per the forum rules (at a minimum the versions of both systems, config settings, error messages in files).
