romain44300
- Sep 12, 2014
I'm fairly new to Freenas and I had successfully setup my own Freenas from scratch. I want now to setup a download manager on a jail.
Kind of plugin:
There is no download manager available as FreeNas pbi so the only way to have my download manager is to create a “Port jail” and setup a freebsd plugin on it.
Which plugin:
I searched on the internet which plugin to install. At first I choose “JDownloader” but I didn’t find an easy way to install it. I found some plugin on http://www.freshports.org so I decided to install “wxDownload Fast” (wxdfast). I chose this one because I want to control my download manager with a web UI from my laptop or from work.
Step to get it working:
My question is simple, is there any help to install, configure and start a download manager? For now I just successfully setup wxDownload Fast thanks to http://doc.freenas.org/index.php/Installing_non-PBI_Software#Installing_FreeBSD_Packages_with_pkgng. But I have difficulties to get it working (I've been trying for the past two weeks but each time I get an error and I have to search on the Internet what is it caused by…).
I’m not a newbie on Linux, but I’m not a specialist and some errors are difficult to understand for me but maybe easy for you, so thanks in advance for your helps!
(PS-1: I’m French, so sorry for any English mistakes).
(PS-2: My "error of the day" is getting "Error: Unable to initialize gtk, is DISPLAY set properly?" on trying to run wxdfast. I have set up Xorg and define DISPLAY in ".cshrc" but I get "No devices to configure. Configuration failed." when I run "/usr/local/bin/Xorg -configure".)
Kind of plugin:
Which plugin:
