DeltaEntropy
- Mar 27, 2022
I'm running TrueNAS-12.0-U8.
So I'm basically wanting irssi to automatically start when the jail starts. I'm wanting to use:
The above command works fine just from the CLI. I can -r into the detached screen and everything is working as expected.
So reading quite a few posts, I have created the following script:
I have placed it in /usr/local/etc/rc.d/ and enabled it with:
sysrc irssi_enable="YES"
I've verified that the script works by manually running it. It's just the startup that doesn't seem to be working.
I've also tried adding the "@Reboot..." line to crontab but that doesn't work either.
I'm aware that I could just setup a PRE/POST INT task, but I'm wanting it to automatically start on the jail start, instead of having to restart the whole system.
What am I doing wrong? Is my smooth brain too smooth?
screen -d -m irssi
#!/bin/sh . /etc/rc.subr name=irssi rcvar=irssi_enable start_cmd="${name}_start" stop_cmd=":" load_rc_config $name irssi_start() { screen -d -m irssi } run_rc_command "$1"
