I have a WD red 4TB USB harddrive,and I plugged into my FreeNAS computer
This HD has a white LED, when I safely-remove from Windows or Linux , it can spin down , and the LED start to blinking every second , it’s safe to unplugged
but I use this HD on FreeNAS , after i shutdown the FreeNAS, the HD is still running, the LED is always ON
I hope when I shutdown the system, the HD stops running , and the LED blinking to give me a safely remove signal
is there any short way to made this function?
thank you all
thank you all
