I'm currently trying to setup FreeNAS.. However I'm having issues hotswapping the drives?
I have it set as a RAIDZ2 Volume.
To test hotswap I basically pulled out ada0 whilst the system was on, checked the RAID Status and saw it was "Degraded". So I then placed a new 3TB into ada0.
Using camcontrol identify ada0 I can see that the system has detected the new disk as it shows the correct serial number. However I cannot use the disk to "Replace" into FreeNAS, and it doesn't appear in "View Disks".
Using "dmesg | grep ada0" I get the following:
Any suggestions or advice is greatly appreciated.
Hotswap is a necessity for this system..
