quantumnerd
- May 26, 2013
I've just put together my FreeNas 8.3.1 box, and everything worked great. I love the interface, and I managed to get CIFS working with raidz2 with not too much hassle.
The major problem though... the read/write speeds horrify me. The WD Red 3TB drives, alone, over SATA are supposed to get somewhere around 110MB/s read speeds. I know raidz2 is double parity, and I know I'm using 5 drives instead of 6, but that still doesn't completely explain the poor performance I'm seeing: 10MB/s reads/writes over CIFS. To eliminate any possibility of the network being responsible, I transfered a large 1.5GB .avi video file to the NAS and used DD to copy data from the array to itself, getting the same speeds. I realize I should have probably been copying zeroes to avoid reading and writing at the same time, but that's still slow.
I started to think FreeNAS was responsible, so I switched briefly to Nas4free. That was painful (especially since Nas4free is rather brittle and needed to be continuously reset to factory since saving settings would periodically break) but from a Nas4free-generated raidz2 array over CIFS I got read/write speeds of 42-60MB/s. That's a lot higher!
Any ideas on how to make FreeNAS perform anything like that?
Hardware:
16GB DDR3 @ 1066Mhz
ASUS C60M1-I motherboard (AMD C-60 dual core processor)
5x WD Red 3TB
Hardware:
16GB DDR3 @ 1066Mhz
5x WD Red 3TB
