SOLVED Help with VPN and IOcage VLAN jails
Surpher
Hi All,
I'm having an issue with connecting to my vnet jails over openvpn. Let me describe my setup:
Router box (10.20.30.1) runs OpenVPN server (10.8.0.0)
* Freenas (igb1 ethernet iface) (bridge0 has igb1 and all vnet0 interfaces for jails)
   *  Sample jail (vnet0:1)
When I'm on my LAN I can connect with the jails no problem.
When I'm on a remote network, and OpenVPN client to the router I can connect to any real box including the freenas box. However, I'm not able to ping or connect in any way to the jails.
If I ssh into the freenas box and run tcpdump, ping requests look like this:
root@freenas:/mnt/iocage/jails # tcpdump -nni igb1 icmp -vvv
tcpdump: listening on igb1, link-type EN10MB (Ethernet), capture size 262144 bytes
12:14:46.345234 IP (tos 0x0, ttl 63, id 37872, offset 0, flags [none], proto ICMP (1), length 84)
	10.8.0.2 > 10.20.30.50: ICMP echo request, id 59699, seq 0, length 64
12:14:47.345708 IP (tos 0x0, ttl 63, id 54233, offset 0, flags [none], proto ICMP (1), length 84)
	10.8.0.2 > 10.20.30.50: ICMP echo request, id 59699, seq 1, length 64
Where 10.8.0.2 is the ip assigned to the VPN client and 10.20.30.50 is a jail. And it appears that the jail is not responding.
Can anyone give any guidance on how to debug or solve this problem?
Thanks
Surpher
This was something dumb, the vnets all had the wrong subnet mask. So the fix was to edit the config.json and append "/24" to each ip address.
:oops:
