I need some help getting access to my TrueNAS server remotely.  I used to have things setup where I could use DDNS and port forwarding, but then I changed ISPs and routers and I don't seem to have the ability to make that setup work. Besides, I think the VPN option is the safer, better route.
Here is my network setup: I have T-Mobile Home Internet, but the gateway is dumb as bricks and has no advanced features for port forwarding or anything else. I use Google Wifi routers which are a little smarter and can do port forwarding and VPN passthrough, but no client/server ability.
I have done the initial steps to setup the Certificate Authorities and Certificates in TrueNAS. I mostly followed this video (link). When I get to the "Download Client Config" button, I get an error saying 'remove certificates' and the following...
I have also looked into third-party VPN services like Proton and Nord, but I'm not sure that is the same thing and I have not been able to figure out how to implement those. NordVPN has Meshnet, which I think would be a good way to be able to access the server remotely, but I think it requires the use of their client software, so I could potentially set that up with a Docker service or in a virtual machine.
If you could help me with some clear directions, I would really appreciate it. I am not a professional IT, networking, or computer person at all, but I have been tinkering with Linux for a decade and have run an Ubuntu/FreeNAS home server for a good number of those years, but it's mostly from recipes I have found online. So I know a little more than the basics, but usually need some hand-holding.
Thanks!
Code:Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 181, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1255, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1284, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1152, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/vpn.py", line 440, in client_configuration_generation await OpenVPN.common_validation( File "/usr/lib/python3/dist-packages/middlewared/plugins/vpn.py", line 199, in common_validation if data.pop('remove_certificates'): KeyError: 'remove_certificates'
Thanks!
