 - Jul 2, 2019
Background:
I have created a VLAN (numbered 101) for the 192.168.101.0/24 subnet on the pfSense router and within the Unifi Controller.
I have the Unifi switch port set to all VLANs. I have tried setting the switch port to only use
I created
The VLAN interface
I can confirm from the FreeNAS console that I can ping the pfSense VLAN gateway of 192.168.101.254
I created the jail with:
Basic Configuration
One other thing: I need to reboot the FreeNAS box (a real pain in the buttocks ;) as my ESXi hosts reside on an NFS mount) when I set up the VLAN as networking stops working outside of ssh to the FreeNAS box and the NFS network (on another, separate physical interface
Any help/suggestions appreciated and welcome!
Config below for mobile users:
			- I have VLANs on my pfSense firewall - working fine
 - I have my UniFi switch using the VLANs - working fine
VLAN101 as well.I created
VLAN101 on FreeNAS on an interface (igb3) that was not otherwise used.The VLAN interface
igb3 is shown as up in the GUI.I can confirm from the FreeNAS console that I can ping the pfSense VLAN gateway of 192.168.101.254
Basic Configuration
- VNET - enabled
 - Berkely Packet Filter - enabled
 - IPv4 Interface - vnet0
 - IPv4 Address - 192.168.101.1
 - IPv4 Netmask - 24
 - IPv4 Default Router - 192.168.101.254
- interfaces -
vnet0:bridge101 - vnet_default_interface -
vlan101
igb1; igb0 is the FreeNAS host interface in 192.168.20.0/24). The web page no longer is accessible. I tried restarting the network stack with /etc/rc.d/netif restart but that did not seem to work and "broke" ssh connectivity.Any help/suggestions appreciated and welcome!
- Operating System: FreeNAS-11.2-U6
 - Chassis: Supermicro SuperChassis 825TQ-R740LPB 2U 8 x 3.5" Drive Bays
 - Power Supply: 2 x 740 Watt PWS-741P-1R Power Supply Platinum
 - Backplane: Supermicro BPN-SAS-825TQ 8-port 2U TQ (W/ AMI 9072)
 - Motherboard: Supermicro X9DR3-LN4F+
 - CPU: 2 x Intel Xeon E5-2630 V1 Hex (6) Core 2.3GHz
 - RAM: 32GB DDR3 ECC (8 x 4GB - DDR3 - REG)
 - Storage Controller: LSI 9210-8i 6 GB/S
 - Boot Pool: 2 x Kingston AS400 120 GB SSD Mirrored (using motherboard SATA 6 GB/s)
 - Pool_1: 5 x WD Red 3 TB RAIDZ2
 - 2 x MiniDLNA servers (seperate subnets) with shared content
 - NFS server for VMware ESXi 6.0
 - CIFS for Windows clients
