Help with install, kernal panic
jimb0b
Hi trying to do a fresh install and am getting the following error (attached image) either on usb or cd, any ideas please
D
dlavigne
Guest
Post your hardware specs and the command you are using to burn to USB or CD.
jimb0b
Of course, thanks for the reply.
asus p5n-mx mobo
core i3 cpuu
2gb ram
4x 2TB wd green hd's
i burned the .iso with imgburn
and the usb via some windows tool
the install go past the basic gui menu to the screen i posted
jimb0b
have tried different versions of freenas now as well, going back to 8.2 and still getting similar errors =(
Glad the BIOS update fixed your immediate problem. Unfortunately, your hardware is still not suitable for FreeNAS. Increasing the RAM to 8 GB would be a start, but swapping in a server motherboard would be the best bet.
