Help with first Freenas build
louiecola2
I am planning to build my first freenas but not to sure if it possible to do what I want. I would like to make a backups of all hard drives in the freenas box just in case one of them were to go bad. is this possible and how would I go about doing this?
praecorloth
It sounds like you're just looking to RAID your hard drives. FreeNAS definitely does that. Do you want this FreeNAS machine to be the destination for backups from a desktop and/or laptop? FreeNAS can do that, too.
Tell us a little bit about either the hardware you either have or might get for this box, and also tell us a little bit about how you see this FreeNAS box serving your needs.
The answer is yes as long as you can use one of the protocols that FreeNAS supports to allow access to the zpool/ufs drive. So you need to examine what program you use, the OS you are using, and find the correlation. For 99% of users, you can do it if you have the technical knowledge to do all of the setup.
louiecola2
I plan on using this for storing movies like a media storage, storing family pics and movies and music. Which I would be playing them all through a media player that is hard wired to the network with a gigabit switch. Here is the hard ware that I am thinking about getting.
Motherboard- http://www.newegg.com/Product/Product.aspx?Item=N82E16813130709
Processor- http://www.newegg.com/Product/Product.aspx?Item=N82E16819113329
Memory- 8gigs DDR3 1066
Storage- 8 terabytes of storage
Yatti420
The motherboard while having higher ram support doesn't support ECC.. It's a decent desktop choice.. Wouldn't use that here.. If you are willing to risk it use Freenas with zfs on it.. http://www.newegg.com/Product/Product.aspx?Item=N82E16813182253 (any x9 not nesc this 1) is most likely what I am upgrading to..
louiecola2
I am trying to build this the cheap rout because of money, so if you can recommend something that would be great. Also I would like to be able to run freenas from sdcard rather than take up a sata port on the board. In the future I want to be able to put 8 drives in, also I do have a raid control http://www.newegg.com/Product/Product.aspx?Item=N82E16816115072 to use in the box
Yatti420
For 8 drives.. Try looking at some more expensive SuperMicro boards..
gpsguy
Active Member
For hardware recommendations, see the thread: So you want some hardware suggestions
While you might consider these suggestions to be expensive - I could say the costs are dirt cheap. I manage a 4.5Tb SAN that cost about what a new Toyota Sequoia does.
You ask if you can reuse your old motherboard. Of course you could - though I'd bump it up to 16Gb RAM for the 8Tb of drives. Is it a good idea ... that's a choice you need to make. Read the ongoing thread ECC vs non-ECC RAM and ZFS
Toss your RAID controller. If you need additional SATA ports, pick up an IBM 1015 (about $100 on eBay). It's highly recommended and supported by FreeNAS.
louiecola2
I don't have that kind of budget sorry. So maybe I'll just reuse my motherboard and up the memory to 16gb like you said. Also the board already has 8 6gb sata ports so I won't need the raid controller card then and I'll run the drives in a mirror ZFS then also.
