My system is the Lenovo TS140, 3.4 GHz i3, 16GB ECC RAM. I just purchased two 4TB WD Reds, and all my data is currently on a single 5TB drive. Now I'm trying to figure out the best way to configure my storage. I read through Cyberjock's powerpoint, and numerous threads to get some information. Here's what I'm thinking of my options:
1. Create a vdev(RAID0) with the two 4TB reds in a new zpool configuration. Transfer my data to this, then create a new zpool from the 5TB to be used for backup.
2. Create a vdev(raidZ) with all three drives, and rely on email alerts (and scrubs/smart tests) to notify me of possible drive failure. In which case, I overnight a new drive to replace the one in question.
I am leaning towards option 1 because I have a guaranteed backup that won't be affected should one of my vdev's fail. I'm a little nervous of putting all my eggs in one basket with option 2. Also, I'm not confident in the long-term lifespan of my 5TB (I pulled it from a seagate expansion external, and its a couple years old).
I've done my best to understand vdev's, zpool's, and RAID's, but clearly I don't have a lot of experience. I appreciate any thoughts on my options or even a different suggestion if you have one. Sadly, buying new disks isn't an option for my right now (except in the case of an emergency). If I forgot to add something, I will. Thank you!
