SOLVED Help with Cron Job shutdown
rhconcepts
I'm very new so forgive me, but I have searched for the answer but not finding what I need. I made a cron job to shut the PC off and its working. But the job is set for 12am and that's the part I cant change. I saw a video on the matter for TrueNAS but I can't find it now. In the video it had more options then what i'm seeing.
Samuel Tai
Click the down arrow on the right, where the schedule appears.
rhconcepts
Thank you, for some reason I didn’t see the custom selection. I also had the wrong command so it wasn’t running unless I clicked test.
Samuel Tai
cron runs with a limited PATH, so always use the full command path in your cron jobs. I.e., use /sbin/shutdown in your job.
rhconcepts
Thank you, I now have /sbin/shutdown -p now
