Hi all,
I'm trying to get Emby to work on FreeNAS. It's in it's own Jail, however it doesn't have access to the mount point I've created. Emby runs as the user "emby" within the jail, but the files within the mount point are set to "rwxrwx---", with "root" as owner, and "wheel" as group. Typically I'd just add "emby" to the wheel group, but that doesn't seem to work. I believe it's because the permissions are being enforced by the target of the mount point (within FreeNAS as opposed to the Jail), and the "emby" user doesn't seem to exist on the FreeNAS system, only witihn the jail, so I can't add "emby" to the "wheel" group on FreeNAS.
Further complicationg the issue is that I'm using Windows ACL's within the mount point target, so I can't just chmod/chown. I'm not entirely sure how to grant the "emby" user within the jail access to files within the mount point. Can someone point me in the right direction?
Thanks
Thanks
