Help understanding "daily security run output"
shimon
I have a FreeNAS Mini XL and I've received two "daily security run output" messages which I do not understand (they are much over my head). Any advice or help deciphering these would be appreciated.
I received the first message yesterday:
freenas.local kernel log messages:
> (ada8:ahcich15:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
> (ada8:ahcich15:0:0:0): CAM status: ATA Status Error
> (ada8:ahcich15:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT )
> (ada8:ahcich15:0:0:0): RES: 51 04 10 31 71 40 03 01 00 00 00
> (ada8:ahcich15:0:0:0): Retrying command
> (ada6:ahcich13:0:0:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00
> (ada6:ahcich13:0:0:0): CAM status: ATA Status Error
> (ada6:ahcich13:0:0:0): ATA status: 51 (DRDY SERV ERR), error: 04 (ABRT )
> (ada6:ahcich13:0:0:0): RES: 51 04 60 4f bb 40 b5 00 00 00 00
> (ada6:ahcich13:0:0:0): Retrying command
-- End of security output --
And the second message today:
> (ada8:ahcich15:0:0:0): READ_FPDMA_QUEUED. ACB: 60 30 f0 30 71 40 03 01 00 00 00 00
> (ada8:ahcich15:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC )
> (ada8:ahcich15:0:0:0): RES: 41 40 10 31 71 40 03 01 00 00 00
> (ada8:ahcich15:0:0:0): Error 5, Retries exhausted
shimon
The messages would suggest you have a drive (or two) failing. Do you have regularly scheduled SMART tests?
I didn't set it up because there was this note in that section of the manual you linked to: "To prevent problems, do not enable the S.M.A.R.T. service if the disks are controlled by a RAID controller."
I thought the FreeNAS mini XL uses a RAID controller for the drives. I have the 32TB version (8 drives) and believe I set it up as RAID-Z3.
Am I misreading that note about SMART and RAID?
m0nkey_
The drives on the FreeNAS mini are directly attached.
@dlavigne:
To prevent problems, do not enable the S.M.A.R.T. service if the disks are controlled by a RAID controller. It is the job of the controller to monitor S.M.A.R.T. and mark drives as Predictive Failure when they trip.
Should the note about RAID controllers be dropped? As it's typically recommended to not use a RAID controller under any circumstance when using ZFS.
shimon
It looks like "Short Self-Test" is already enabled to occur every hour on Sunday. That sounds like a lot. Should I change it to only happen for one total hour instead of every "N (1) hour"? I attached a screenshot of the Task screen. The SMART service is enabled.
But it sounds like I need to add another task for a "Long Self-Test" which should be once a month.
By the way...I appreciate the help.
Robert Trevellyan
Pony Wrangler
It should only be run once on a given day. Overall frequency recommendations vary from daily to weekly.
That's what I would go with. Some members run them more often.
shimon
I found this post: https://forums.freenas.org/index.php?threads/scrub-and-smart-testing-schedules.20108/ which was helpful in setting up proper scheduling for scrubs and SMART.
Ran a short-SMART last night and got this message today:
> (ada6:ahcich13:0:0:0): READ_FPDMA_QUEUED. ACB: 60 70 38 4f bb 40 b5 00 00 00 00 00
> (ada6:ahcich13:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC )
> (ada6:ahcich13:0:0:0): RES: 41 40 60 4f bb 40 b5 00 00 00 00
> (ada6:ahcich13:0:0:0): Error 5, Retries exhausted
So, it seems that drive 6 is bad. I will contact IX Systems for a replacement as this is still under warranty.
I appreciate the help. Thanks.
Robert Trevellyan
Pony Wrangler
That should show up in attribute #197 or #198 in the output of smartctl -x /dev/ada6.
shimon
Been in touch with IX Systems...they are very responsive. They are asking for me to post a file copy of /var/tmp/rc.conf.freenas file.
Can someone help me with the command to do this? I'm not familiar with these UNIX (?) commands yet.
shimon
I figured it out after much Googling of UNIX commands and locating my SMB shares through the Shell. Getting the basics down: cd, ls, cp, etc.
shimon
Just want to update on the resolution to this issue. IXsystems tech support was excellent. The tech actually spent a lot of time helping to actually troubleshoot problem instead of just looking for a quick fix or feeding me canned responses. He listened to me, educated me and helped me solve this issue. Kudos to the IXsystems team.
So, after running some SMART tests and going through debug logs, I swapped the suspected bad drives with other drives (changing slot positions) and the problem never came back. May have just been a reseating issue or something else but I haven't seen the errors again and debug logs look clean.
And I know a lot more about FreeNAS and UNIX now. Thanks for assistance.
