Help! To buy or not to buy? That is my question
tres_kun
Short story
I want to get the asrock EP2C602-4L
And found some ram samsung m393b1k70dh0-yk0 8X8GB
Question will it work?
Motherbord lists as being compatible with ECC Registerd 1866/1600/1333/1066 MHz at 1.5, 1.35V
What does ASRock Rack have to say on the matter?
tres_kun
the specific memory i found is not on the memory QVL list
But the motherbord lists compatibility with Registered ECC memory
I have only ECC unbuffered server memory never had contact with registered memory
Well then, the default answer is "probably, but expect ASRock to use that as an excuse should something break and make you jump through hoops".
